Has anybody use the ZIPPY brand from Hobbyking?
The HobbyKing Zippy 2S2P 50C 6000mAh: http://www.hobbyking.com/hobbyking/store/__18608__ZIPPY_6000mah_2S2P_50C_Hardcase_Pack.html
Very cheap and good performance.
Downside: most of us have to solder a different connector to it, which can be a drawback for many newbies!
Have zippy 4000mah 4s 25c
Have venom 4000mah 3s 25c
Like the venom more. Did loose a cell in a tiny 3s 1800mah when i was screwing around with 3s for the first time.... still took awhile tho
Had a "regular" onyx 5000mah 25c and had it puff up and scare me.
haven't had any issue with the zippy pack but side by side venom soft packs sem like they can take a little more of a beating
Here u go @mrbellosoHas anybody use the ZIPPY brand from Hobbyking?
are the onyx ones not too good?Have zippy 4000mah 4s 25c
hard or soft case? and which one would you recommend?I have 2 venom and 2 onyx 25c 5000mah and can't tell the difference!
as of now im thinking spcHard case.... And depends on what u want to spend .... Venom are more expensive where onyx are the value brand
I hear good things about the spc brand..... Definetly hard case... My thought is because the battery box is on the bottom don't want it to take any damage.as of now im thinking spc
http://spcracingbatteries.com/index.php?route=product/product&path=59&product_id=102
oh yeah, would you rather the hard or soft case?
I've got Flureon 5200mah 2S that I run in my tamiyas and the Arrma - were ~AUD$35 inc postage each.
Venom 5000mah 20c 2s or SPC 5000mah 40c 2s? on paper the spc sound better, but which one?
I go lighter on the throttle, but I like to pull wheelies heheThose are $40 LiPos?
More?
For a 25 min run, depending on conditions.
Here's a 4000mah 2S for <$20 that will give you a 20 minute run.
I know, I have a pair.
FLOUREON 7.4V 4000mAh 2S 30C
I tested my dad's venom (exact same specs as I listed above) is enough power to pull wheelies! will get a wheelie bar, my rear bumper is quickly burning off lolThose are $40 LiPos?
More?
oh yeah, and I probably need a LVM since I have a faulty esc, and even if I had a proper one, I think it would kill the lipos because of the 3.2v LVC
I haven't changed the gearing in my fury, but I think I might try putting the included high speed pinion... would I always be popping wheelies?On that 4000mah LiPo, I can pop wheelies from standing start and when rolling around 20MPH.
Actually, it's harder to not pop a wheelie.
I will be gearing down, both the Vorteks and the Raider.
I've been using Van Battery lipos for a few months now. I own a 6s, a 4s and 2 - 2s and they have all served me well so far.When I got into this hobby about a year ago, I quickly found out that cost can be a barrier to entry if you make bad purchases and bad decisions. When I decided to make the switch to LiPo batteries, I did a ton of research on "budget" LiPo batteries on various online forums. I was looking for a battery that was reliable, good quality, and one that would not break the bank. With that being said, I decided on 2 suppliers: SPC Racing Batteries and SMC Racing Batteries. I run a 5000mAh, 50C, 2S SPC Racing LiPo ($33) in my Fury BLX and could not be happier with the performance. I also run a pair of 2500mAh, 50C, 2S SPC Racing LiPos ($20 each) in my mini E-Revo and a 5000mAh, 50C, 3S SMC Racing LiPo ($40) in my Axial Yeti.
So, what's your battery of choice? Hopefully this thread can help out someone who is just getting into the hobby or someone who is looking for a different pack to try.
