- Illinois
- Fireteam
- Infraction
- Limitless
- Kraton EXB
- Talion
- Typhon 6s
- Typhon TLR
Why not?I agree. Wheels aren't one of them though unfortunately.
Strength. I haven't seen any 3d printed wheels that actually hold up to bashing use. Perhaps I just haven't seen or heard of them yet?Why not?
Strength isn't the issue. It is just difficult and more expensive to design/print good 3D wheels, especially at high quantities. It is slower and more complicated to manufacture.Strength. I haven't seen any 3d printed wheels that actually hold up to bashing use. Perhaps I just haven't seen or heard of them yet?
Surely someone would be trying to sell them by now if it were feasible?
Okay, so be itStrength isn't the issue. It is just difficult and more expensive to design/print good 3D wheels, especially at high quantities. It is slower and more complicated to manufacture.
omg those motors are expensive af! almost 700$ for 1/5th scale motorI was doing the same. Also looked at some Cordova motors. The stock motor is a 3652 I think which I'm guessing means 36mm diameter with 52mm length. Here are some Cordova motors that should fit. I tried to pick KVs that were close to stock for each of the 3 sizes. Some of these can handle up to 5S and there were many other options with much higher KVs in the 2S range. Don't know how that would effect the flywheel motor but it would be nice to see if the bike could handle the jump in power from an upgraded motor.
https://www.yourbatterybuddy.com/in...rch-1-10-scale-motor-1-5-inch-can-4100kv.html
https://www.yourbatterybuddy.com/in...rch-1-10-scale-motor-1-8-inch-can-3600kv.html
https://www.yourbatterybuddy.com/in...rch-1-10-scale-motor-2-1-inch-can-3300kv.html
Here's a chart with most of the Cordova motors listed and grouped by size. (https://www.yourbatterybuddy.com/motors-esc/cordova-motors.html) The 1415, 1418 and 1421 are the closest in size to the stock motor.
Maybe see if they cut ya a deal if you buy a dozen?omg those motors are expensive af! almost 700$ for 1/5th scale motor
What’d I miss??Them boys at Losi better suit up, Facebook mob about to fire up the flamethrowers.
What’d I miss??
Ahh.. I was just watching a 2FMRC vid and he mentioned that. Apparently HH shut down all preorders and upgrade preorders.Allegedly, Losi grossly underestimated demand and orders are getting pushed back ... spin the wheel of Facebook rumors
You can't order the green one with the battery and charger but the red and blue without the battery and charger you can still order.Ahh.. I was just watching a 2FMRC vid and he mentioned that. Apparently HH shut down all preorders and upgrade preorders.
Crazy!
Good news for me I guess, as I really can’t swing one atm..
I am glad to see it’s so popular tho. Hopefully it will be around for quite some time then.
Stop it!! I can’t afford one atm..You can't order the green one with the battery and charger but the red and blue without the battery and charger you can still order.
The guy in the vid I watched uses his old shorty racing packs with bullet plugs that he made an adapter for, I’m assuming the balance lead plugs into the pack also.Yeah that's kind of a bummer but it looks like there should be room to stash it away. I was thinking you could maybe cut off the balance connector and use a set of mini plugs to make it removable.
I was planning on using my 2s graphine packs, they have bullet plugs and no balance leads.. The balance lead is on the charging leadsThe guy in the vid I watched uses his old shorty racing packs with bullet plugs that he made an adapter for, I’m assuming the balance lead plugs into the pack also.
