1. Aluminum Nero Rocker Arms GIVEAWAY
    ENTER NOW!!!
    Dismiss Notice
Giving up on TBone basher front bumper.
Discussion in 'Kraton' started by edvin70, May 14, 2017.
Tags:
  1. edvin70
    edvin70 Well-Known Member
    Feb 8, 2017
    21
    19
    I'm disappointed in the basher from bumper for the Kraton and am swapping it out for the RPM and will also try the TBone Typhon bumper.
    The plastic just isn't strong enough to prevent the bolts from pulling through and is bent downward so that the front ground clearance is reduced. It caused allot of unwanted front flips and cartwheels yesterday. I've tried to heat and bend it back but the inner support piece ensures it gets bent down and away from the chassis on impact.
    If anyone else has had these experiences and came up with a fix I'd love to hear about it.
  2. Bigfella
    Bigfella Well-Known Member
    Apr 11, 2017
    86
    69
    Sorry for your troubles. I never bought the t-bone unit. I have the rpm bumper and it is just about as close to a perfect bumper as you can get. I love mine. Your bumper problems are over with the rpm.
    83N and edvin70 like this.
  3. Trickelitrick
    Trickelitrick Supporting Member!
    Supporting Member ArrmaForum Fan
    Sep 3, 2016
    222
    145
    Sweden
    Landing with bumper as shovel will most likely bend it...done some times...and the plastic rip through the screws. Not sure about a permanent fix to prevent the bolt stuff.......just take a pic and email tbr they will send you a new one.
    Btw i also bought the rpm bumper after a couple of tbr replacements cause i cant stand waiting shipping from usa to sweden lol
  4. Sneaky
    Sneaky Well-Known Member
    Nov 18, 2016
    16
    3
    Happened to me as well, I'm using longer screws and metal washers to stop the bumper pulling through the screws but it is a weakness of this Tbone part.
    Rich Duperbash likes this.
  5. Trickelitrick
    Sep 3, 2016
    222
    145
    Sweden
    Yea wish they would have knobs to fit the holes and all would be juuust fine
  6. typhon34
    typhon34 Well-Known Member
    Dec 30, 2016
    133
    53
    I use typhon front and rear bumpers on my kraton.... Hasnt caused any problems yet even with nose diving off jumps. Kraton bumpers just stick a little to far i reckon.
  7. Sneaky
    Nov 18, 2016
    16
    3
    Yep it's a fundamental flaw given the size of the bumper, there is a lot of leverage there on an impact not helped by the mounting holes being counter sunk with no reinforcement, you have very little meat there to securely hold the bumper in place.
  8. Napalm
    Napalm Well-Known Member
    Jul 6, 2016
    41
    15
    Atlanta GA
    Try putting washers over the holes as a temporary fix. I gave up on any T-bone that looks like a shovel because of the screws pulling through.
    Brandon A likes this.
  9. dpricenator
    dpricenator Supporting Member!
    Oct 25, 2016
    575
    324
    I used the Talion T-bone and it doesn't stick out as far. Never pulled through, and I've nose landed multiple times. I agree the kraton bumper seems to be a problem. It's also an ANTI=SPOILER, At speed, the kratopn and Talion T-Bone Bumpers push the front end up, reducing handling at speed.
  10. Trickelitrick
    Sep 3, 2016
    222
    145
    Sweden
    Bending mostly happens if plowing into grass
  11. AGHolman
    AGHolman Well-Known Member
    Sep 4, 2016
    69
    11
    Austin, TX
    Any idea if the RPM bumper is compatible with the Voltage Hobby skid plate? I know my Tbone bumper won't work with the skid but maybe RPM will. I've also had Tbone pull through on mh X-Maxx but I do like their stuff (other than this issue). Thanks!
  12. slpcrf450x
    slpcrf450x Well-Known Member
    Jan 2, 2017
    174
    74
    Are you putting the Voltage Hobbies skid plate on top of the bumper? I wouldn't think the RPM would work too well because of the ridges. I don't see why you couldn't put it over the T-bone with long enough screws.
  13. 83N
    83N Well-Known Member
    May 5, 2017
    47
    UK
    So... You want to stack 2 skid plates - things that have a very specific role and fitment - together?
    #13 83N, May 18, 2017
  14. edvin70
    Feb 8, 2017
    21
    19
    I just received the RPM bumper and the plastic is thick and very sturdy, I don't think and additional skid plate will work or necessary. The RPM design is more of an extended skid plate, there is no flex in this bad boy.
  15. jonUF02
    jonUF02 Well-Known Member
    Dec 14, 2016
    121
    46
    Orlando, FL
    I've had multiple cartwheels and nose dives, even hit a mailbox post at least 20MPH to dead stop with RPM bumper, no damage. It's great.
    As for extra chassis plate, not sure why it's necessary, but anything can be made to fit with some cutting.
    solidbase likes this.
  16. JvG
    JvG Well-Known Member
    Nov 7, 2016
    16
    10
    The Netherlands
    Hi, i've put the Kraton rear bumper also in front, works good!
  17. Swerny
    Swerny Well-Known Member
    May 30, 2016
    189
    62
    Toronto, Ontario, Canada
    I have the same issue with the Tbone kraton front bumper. Screws have pulled through and angled it down.
    Not a good product. No issue with the rear through or the front and rear Vorza bumpers i'm now using on my Typhon.
    Thanks for the reminder, i just emailed T-bone for a replacement. The website says they have "version 2".
    #17 Swerny, May 18, 2017
  18. Brandon A
    Brandon A Well-Known Member
    May 29, 2016
    Alabama
    I'm having the same problem
  19. Sen8trken
    Sen8trken Well-Known Member
    Oct 6, 2016
    12
    Melbourne, Australia
    Thanks for the feedback guys. I think I'll use the RPM unit over the T-bone front. Has anyone had any issues with the T-bone rear wheelie bar kit or the A-Arm skids?
  20. T-Bone Racing
    T-Bone Racing Well-Known Member
    Feb 2, 2017
    1
    Hayden, ID
    Hey guys,
    We're sorry to hear about our Kraton bumper not performing well.
    We'll look into getting the design updated.
    What suggestions do you guy have for an updated design? I've noticed some pictures of our Kraton Thrasher bumpers where the bumpers are flattened out and sticking out way further than they should. The stock angle of the bumper is 120 degrees.
    We're always looking for ways to improve our parts and welcome feedback!
    Look forward to hearing from you.
    Thanks!
    -TBR
Verification:
Loading...
Draft saved Draft deleted
  • Welcome to Arrma Forum
  • Disclaimer
