SrC
RC is a lifestyle choice
Hospitality Award
- Queens, NYC
- Fireteam
- Infraction
- Limitless
- Kraton 6s
- Mojave
- Notorious
- Outcast 6s
- Typhon TLR
11K mah is quite large of a capacity. Probably need a separate PSU with enough Watts to charge them within one hour. PSU Must match the Max volts and amps the Charger specs allow. No more. Need basically a 1C rate. IC rate is the safest and best Rate for lipo longevity. Getting greedy with quicker charge times is not realistic.
Yeah, you need a charging setup that will charge at a sustained 11.0 amp hours.
Or just accept that it will take much longer to charge those very large Capacity 11k Mah packs. Sometimes getting greedy with longest RC run times is not realistic.
And Many guys don't run them because they are simply too Heavy for some models, depending.
