dk10438
- Limitless
- Thread starter
- #21
Thanks for all the great replies. So a couple things. As previously noted, 1c charge rate roughly equates to 1 hour charge time from a depleted battery (10-15%) to fully charged (not counting balancing). Therefore, if you are charging at "2c" and it's taking longer than 1 hour you really aren't charging at 2c. So charge rates will depend on cell size, total capacity and the charger. My understanding is it's (cell) x (4.2v) x (capacity)= Watt/c. For example, to charge a 6s 10 amp battery at 1 c would be 6 x 4.2 x 10= 252W.
There were a few assumption made regarding charging. First, I normally store at 50% capacity which may be wrong since everyone here appears to be storing at 70%. Second is sometimes I "field charge". I have some old lipos that I used to have in a multi rotor that I'll charge up and use as a DC source hooked up to portable ISDT charger to charge while I'm driving. These lipos are being charged from a nearly depleted state and 1c v 2c would actually make a pretty significant difference.
Sounds things have changed back to 1c so I'll have to rethink my charging habits.
