- Rhode island
- BigRock 4x4
- Kraton 6s
- Outcast 6s
- Vendetta
- Infraction 4x4
Like mentioned it's Aquarium tubing..that's all that this is...
It's the same type of material that is used for alligator clip covers.I still say it's fish (tank) tubing.
You don't need it unless you like the clear view.
I run my sh!t the same way without that clear plastic piece perfectly fine. I run one male and 1 female plug on my packs depending on the unit with 0 problems. Mainly for less connections when in series. Only thing is the different plugs I need to charge them with, but it doesn't really bother me.Short story long I want to copy this idea so I can extend the super short wires on the Castle MM2 so that I can run the battery tray in the rear position on my Fireteam and also do this mod to all of my 6s escs so instead of needing 16 XT90 connectors I only need 2.
https://www.radiocontrolpower.com/qs8-xt90-anti-spark
Yep. If they start to become a bit loose, I'll use a Torx driver to spread the bullets apart a bit, then they are in there tighter than a bull frogs butthole.So the bullets hold together just fine?
Is best for what? Have you even understood what he needs it for or is whatever assumption you've made sufficient to you? Whether it has anything to do with what he needs it for is a question that just doesn't even seem to enter your peripheral vision. Clear shrink tube has its place...this isn't one of them.You don't need it unless you like the clear view.shrink tubing is best honestly.
Maybe they added those as a way to prevent someone from accidentally trying to plug them in the wrong way?Yep. If they start to become a bit loose, I'll use a Torx driver to spread the bullets apart a bit, then they are in there tighter than a bull frogs butthole.
Could be. I've seen some pretty messed up things that people do in this hobby as you have as well. For me it's pretty hard to mess up Black to Black/Red to Red.Maybe they added those as a way to prevent someone from accidentally trying to plug them in the wrong way?
Could well be. As we all know, safety comes third. Or possibly to increase the water resistance of the connection?Maybe they added those as a way to prevent someone from accidentally trying to plug them in the wrong way?
People am dumb.Could be. I've seen some pretty messed up things that people do in this hobby as you have as well. For me it's pretty hard to mess up Black to Black/Red to Red.
Yeah, but that's only because you're not color blind.Could be. I've seen some pretty messed up things that people do in this hobby as you have as well. For me it's pretty hard to mess up Black to Black/Red to Red.
Maybe braille on wires moving forward is in order?Yeah, but that's only because you're not color blind.
That's brilliant. I just raised a few nubs on a piece of paper to remind myself tomorrow to put that into production.Maybe braille on wires moving forward is in order?
I am color blind. I have Deuteranomaly.Yeah, but that's only because you're not color blind.
That sounds safe. I've just been running down the street with a Blutooth speaker making RC noises in my hand, they honestly can't tell the difference. But I have to admit...I like your idea better.Speaking of..
Do Blind folks RC too?
If so, do they speed run.. going strictly by sound??
