Does anyone know what the smallest pinion you could put on the outcast is i fit an 11 on there looks like it has a hair more adjustment for a 10t but i don't have one to test it stock spur
No it's not even that lol i can't keep these dang temps cool I've done everything new bearings checked rolling resistance without the motor installed truck rolls as free as it will ever get lol after halfway through 6s pack 200+ degrees even installed a fan still around 190+ i was gonna try to gear down i shed as much weight on this rig as i could too roll bar , reciever box,hardware i removed about 300 grams of extra weight possibly don't matter but less stuff to disassemble
I doubt it's the battery usually there esc will get hot if your battery isn't strong enough my esc only reaches 110 degrees and same for the battery after a full 20 minute bashWhat battery are you using? C rating?
Lol it's all good and 1 million wt center diffyou have Very high temperature..
Today I used my outcast with 8 ° C outside temp, for 20 minutes, with 16T pinion and the temperature is 52 ° C and engine 29 ° C esc, with 6s 5200mah 90c / 180C ... the oil in the central diff how many cst ? Sorry for my bad English but I wrote from Italy ;-)
How old is the truck and how many times have you run it it damp conditions? Could be a bearing in the motor that's causing your heating issues.No it's not even that lol i can't keep these dang temps cool I've done everything new bearings checked rolling resistance without the motor installed truck rolls as free as it will ever get lol after halfway through 6s pack 200+ degrees even installed a fan still around 190+ i was gonna try to gear down i shed as much weight on this rig as i could too roll bar , reciever box,hardware i removed about 300 grams of extra weight possibly don't matter but less stuff to disassemble
4 months old i have put 3 motors in it same outcome look at my old posts never drive in water had this truck completely torn down to many times everything is shimmed and spins freelyHow old is the truck and how many times have you run it it damp conditions? Could be a bearing in the motor that's causing your heating issues.
I have a total of 7 batteries 4 4s and 3 6s lipos different brands and it does the same thing even with 4sCan you borrow a different battery to try? Just to eliminate things? I know nothing about that brand other than it's a $72 6s battery and usually you get what you pay for.
I had 100k comes with it stock still overheated with that weight so im not sure[Quote = "Slicktmi post: 100944, membro: 8300"] Lol è tutto buono e 1 milione di centro peso diff [/ QUOTE]
For me 1.000.000 cst, not good and the motor make more stress, for turn the diff...I used 100.000cst, and today I have make my speed record of 66,05mph...you can see my tread...For me, if you change the diff cent oil, until 200.000 you have reduced the motor temp.
Lol my reaction exactlyDear God why?! ?
