Kraton Lihv stock electronics
Kiba.k9
  2. Kraton EXB
Will lihv work on stock electronics I don't know but I'm for sure going to try it I've heard that it will send it right yes I could have done .5 more volt but eh
Probably not, but you could disable LVC and run an external voltage check periodically if you don’t have smart/telemetry
If it don't let her burn I'll put a hobby wing setup in it
It will work with no trouble, you start at a higher voltage so you get a little more of "life" from your lipo but at the same time you need to modify your cutt of voltage to not let them go down to low
Kinda cart wheeled on blacktop fixed back to the park with a fresh battery I had spare end links and I lost the dog bone 😢
But I had a jennys drive shaft set for this reason and replacement parts on the way to keep my stock fresh
I keep a full set of drive shafts and ball cups on hand I also have the turn buckles in titanum for when they bend 🤣 I just didn't have my spares with me I was 5 min from the apt
