Mr.White
- Thread starter
- #21
That's interesting. I have been using it on 5S with the stock motor and new ESC for a couple weeks now with no issues.If you are running the stock Arrma ESC it cannot detect 5s batteries. It is detecting your fully charged 5s battery at 21 volts (4.2 volts per cell) as a 6s battery at 21 volts (3.5 volts per cell) and is hitting the low voltage cutoff. You need to switch the ESC to NIMH mode and run an external voltage alarm.
That being said, I'll give the 6S a wing tonight and see what's up. Thanks!
