- Thread starter
- #41
That makes sense to me. I know with lower grade chargers, if cell voltage is too low they throw an error message and won't charge the pack at all.Alright I just did some quick googling on the topic and it seems to mean something a little different than what you're stating. At least with the information I found.
The trickle charge feature activates when a cell's voltage is low, not once the charging cycle is complete. It is intended to carefully/slowly bring low cells into a safe range before pumping the requested amp rate during the charge process.
I couldn't find anything from Hota though. And I don't know how credible these sources are, so take this as you will.
https://chinahobbyline.com/blogs/news/staged-charging-of-1300mah-22-2v-6s-lipo-battery
https://oscarliang.com/choose-lipo-battery-charger-power-supply/
To circumvent this, after accidentally overdischarging a pack(I turned off LVC), I plugged the pack into said charger without the balance lead connected. Let it charge at normal rate for a few minutes to bring up the low cell, then stop charge, reconnect balance lead and restart charge cycle..all good.
