- Talion
Keep breaking the same things in the car, and not sure if there is anything else I can do.
My car is fully beefcake m2c built, then mostly HR racing parts and castle 1717 motor combo - Talion EXB RTR.
It's newly built in November and now has about 100 packs through it - mostly at the track.
I have now
The other thing that fails me all the time is wheels, I constantly crack the rims on the far edge away from the face (inside of the wheel). I've broken maybe 6 rims? I never wear out the rubber first. I usually break a 140mm sized rim in a few packs (and I crash frequently). I'm just running them with the little cracks in them anyway now....
Not much else gets damaged...the oddball item.
I don't mind the EXB arm being broken, because it's not too hard to replace and you need a sacrificial piece, but I'm a little miffed I'm breaking m2c hardened pin, it's not an easy part to replace when the car is all buttoned up. The m2c A & B hinge pins block, and the HR bulkheads are solid, so are the m2c CVDs.
These are really the 2 or 3 weakpoints left.
Anywho, I wish the damage would stay contained to the EXB arms, or at least have a heavy duty RPM arm option for the EXB - please
Maybe a titanium m2c hinge pin? That fits an EXB front block so there is no nut on the back end? - please
I have now
- Broken the m2c lower front hardened hinge pin three times (shear snapped to pieces) and cracked another.
- cracked the upper front stock EXB a-arm at the exact same spot three times
- I'm also wearing out the EXB diff drive cups, especially when the dogbone end of the cvd jumps out of the drive cup. I think I've solved this by removing all the spacers possible on the front end.
