- Tennessee
- Felony
- Infraction
- Limitless
- Kraton EXB
- Mojave
- Outcast EXB
- Senton 6s
- Vendetta
Plus it just looks cool lololol
I used Typhon 6s adjustable steering link turnbuckles.Which arrma turnbuckles and turnbuckle ends did you use? Do you have any part numbers? Any Pics?
Is that a Kraton 6s V4/V5? And are they the rear upper arm linkages for the V4 or V5.. might be the same I'm not sure
The 8mm diameter option broke on a wing landing plus tumble from about 10ft high - broke across the sides of the hole at the top - the obvious weakest point.The nylon66 ones were working really well, no breakage, no bending. So I've had some made up properly in 8mm and 10mm diameters in SLS printed nylon12 to test out. Various versions to allow for wing mount to be high/low or not.
https://www.arrmaforum.com/threads/goodies-turned-up-from-the-printer.41590/
pretty cool, i just remove my rear wing,with wheelie bar, and use a wing mount i bought earlier that broke and run with the rear rpm bumper when doing jumps. i actually have a rear wing mount and wheelie ready to attach in the field if im running on flat grass, asphalt or dirtGot the idea from FB, on the Arrma Tips & Tricks page.
94mm Traxxas 2338 turnbuckles...some decent thickness washers, and 20mm button head screws.
Insane how much this firms up the wing mount...tail landing are a little less scary now, we'll see how she holds up!!
View attachment 10338 View attachment 10339 View attachment 10340
Do you still sell these??New MJF printed Nylon PA11 (un-dyed this time) structs arrived for testing today, PA11 certainly seems far more flexible and durable than PA12 to feel, time will tell how they fair in reality.
I've also redesigned them it fit into the recess in the hinge pin retainer so less load is taken on the bolt and more in just compression through the hinge pin retainer and onto the chassis.
View attachment 160998View attachment 160999
