Jluther@becoinc
- Senton 6s
- Talion
Qs10 u don’t need them unless u plan on running 200mph. I use xt90 anti spark for 6s and under. 8s and above I use qs8. I would use qs10 for like 12s. But they r great connectors. Expensive but if u want the best gotta pay for it. U get what u pay for literally imo.Try a QS10
If your connections are the same temp as the wires and batts, you are fine. If the wires and batts are hot and the connections are hotter, you have bad contact or a bad solder job. Bad contact is an easy sliding connection, you want to feel those bullets getting squeezed when you push the connectors together.I been using XT90’s on my rigs since I bought my first Kraton V2. They came stock then. What connector would be a size bigger. What kind do y’all use besides EC5?
I was crap at soldering was using a cheap soldering iron. got a more powerful soldering iron now its a lot easierQS8 is the ones I couldn’t remember the name and there’s a lot of good information in the video. My connectors may just need replacing. I get my LHS to solder my ends on . Depending on which guy does it they usually do a good job. I have tried soldering but just don’t trust my ugly soldering. I just can’t get the feel for it! I keep trying and keep screwing up connectors.
I have no experience with them and the Post said XT90’s getting too hot so why would I go to a connector I have no clue about. And I’m not sure what “Bad experience. inquiring minds must know” even means? I’m guessing English isn’t your first langue? Not trying to make fun it’s just kind of weird.what’s wrong with qs-8s. Didn’t see u reference them. Bad experience. Inquiring minds must know. Lol
ESL and mentally handicapped, a great combination.Must not b smackers
U must’ve gotten bullied in highschool. Not my fault. Lol
I was simply saying because u said bullets and ec5 so I ASSUMED u had a bad experience. My apologies genius
