Velodromed
Snatching defeat from the jaws of victory!
- San Antonio, TX
- BigRock 4x4
- Granite
- Kraton 6s
- Kraton 4s
- Notorious
- Outcast 4s
- Vorteks
- Voltage
- Infraction 4x4
- Thread starter
- #61
I’ve heard that from several people and have no idea why but if I PM you first you should be able to communicate with me so I will in…right now. Hold tight lol.@Velodromed
So I'm trying to see your Profile and start a PM with you, but I'm un-able to...
Your Profile is locked or Barring me from doing so. Just so you know.
Cause I want to speak to you in private ,on certain matters.
Shimming the bottom 3d printed support with layers of adhesive backed foam as needed (1/8-1/4") may pick up any slack with various pinion sizes.
The 3D support printing should be sized, height wise, with the smallest anticipated size pinion. (w/Motor slid all the way inward) Shimmed with foam to compensate for the larger pinion sizes, as the motor slides outward to varying degrees.
But honestly, I never bent my stocker motor mount without a support under the motor..
Never thought about it much.
Not sure if you’ve seen me drive but I think you’d understand my interest in this if you did. It ain’t pretty at times
