- Rhode island
- BigRock 4x4
- Kraton 6s
- Outcast 6s
- Vendetta
- Infraction 4x4
Yup those are the typical size I use .as for the rear I'm all set .I already have red led strips plus a led at the bottom of my diffuser.Im really just concerned about the front .I'm going to start this in a little bit .later I'll shoot you over what I came up with.as for how much clearance I have under the cover when it's on the chassis .thank youYeah that should be enough, then i'd just need to know the angle on the front ones. The rear ones id assume don't have much of an angle, but if they do provide that as well. You could even take cardboard and tape and make the entire bucket if you want me to get it right the first time, this would really be best.
Edit:
These are the most common metal led holder we all use, on the back side of the light bucket i was gonna design holes to fit these, up to you? If not what size hole do you want, just the size of say the led itself in this picture.
https://www.amazon.com/ShareGoo-Hea...qid=1705768454&sprefix=rc+leds,aps,106&sr=8-8
I think it's best if I use the metal bezel so the light can be directed forward rather just the led light bulb it self which will spread the beam outwards.i do have plenty of them metal bezels.i can allways send you also a harness so you can dry fit them..I have two sizes in the bezels.the ones I want to use is the Large size .the smaller size I use them for fogs or cursersYeah that should be enough, then i'd just need to know the angle on the front ones. The rear ones id assume don't have much of an angle, but if they do provide that as well. You could even take cardboard and tape and make the entire bucket if you want me to get it right the first time, this would really be best.
Edit:
On the first page of this thread I posted pics of this c8 cover .also a rear pic of the led light I made on the diffuser that runs off of two 4" strips on top of the rear diffuser.i can see this car from far away.its lit up like a Christmas tree.
