- Tennessee
- Felony
- Infraction
- Limitless
- Kraton EXB
- Mojave
- Outcast EXB
- Senton 6s
- Vendetta
Well I have had a lot of PM's / Interest in my custom made hood scoop. Figured I would make a separate post on it at this point. I have made a new revision as well on the lower half. And yes it works so well you really don't need fans lolol, not saying you should rip your fans off, but its that good, pictures don't do it justice, it's huge and creates a ton of air flow!!
I'm sure this is doable on an infraction but as I don't have one I cannot map it out for you.
1. First cut a hole in your body like so... Don't put the 4 screw holes in yet.
2. Now print the upper and lower intake, free on my thingiverse, https://www.thingiverse.com/kuskye25/designs
3. Once thats done use either the upper or lower intake as a template to make your 4 holes in the body.
4. Now assemble, the holes are made for M3 screws.
5. Enjoy your amazingly and potent new cooling system lol. Flames are optional but available for download as well!!! You will need to heat the flames once done and make a bend in them before gluing them on them.
