- God’s Country
- BigRock
- Fireteam
- Granite Grom
- Infraction
- Mojave
- Notorious
- Typhon 6s
- Typhon TLR
I don't understand why a decent transmitter couldn't use the reverse input of the trigger as a variable mechanical brake(servo control), basically becoming a gas/nitro. You would just lighten or remove the ESC's brake parameter.
Unless you want to be able to brake while under acceleration power, which as you found out creates heat throughout the entire system.
