rchelipiloteer
Is this spur gear worth the price or just buy a whole new diff for about ten bucks more, thanks!
SixOn a 3s rig? if so you need to add a slipper pad to the mix to run the steel spur. You could also see if jennysrc has the whole 4s outcast/kraton one in stock and drop it in. On the 6s rig the stock spur is fine in the center.
got a used car with probably 60,000 miles on it hahaI've never had an issue with Arrma spur gears, even on bigger motored trucks.
HR stuff is very hit and miss, with more miss than hit in my experience
