blakeaowen15
how can i get my stuck sun gear out of my crown side?
I like the cut of your jib.I’ve had great luck just flipping the diff over on a paper towel. After two shots of Tito’s and a cigarette just come back, lift it up, and you’ll see your sun gear sitting pretty on that paper towel.
This method doesn’t seem to work without the Tito’s, though…
Thanks for saying, but these days I’m wishing my jib wasn’t quite so hacked up.I like the cut of your jib.
Same. When I was younger I would have cared. Now? Not so much. Enjoy that hacked up jib. I know I do.Thanks for saying, but these days I’m wishing my jib wasn’t quite so hacked up.
got them out thanks now I got another question. How do you get the main output out when it’s stuck on the crown sideYou can use two flat head screwdrivers and pry up evenly 180 degrees from each other..
You can use needle nose pliers as well, but a little caution is needed.. they can slip off and rake the teeth of the gear.. a light slow pull will usually be the best method if using pliers..
typically these are just stuck from the fluid, creates a suction when trying to pull them..
I wouldn’t trade my jib for anything. It’s got street cred, man!Same. When I was younger I would have cared. Now? Not so much. Enjoy that hacked up jib. I know I do.
Pull the pin sideways out of the outdrive shaft on the inside of the diff with a pair of needle nose pliers.got them out thanks now I got another question. How do you get the main output out when it’s stuck on the crown side
i got the pin out before but i’m talking about it coming out even with the pin out it’s not wanting to come outI wouldn’t trade my jib for anything. It’s got street cred, man!
I’ve never experienced that. Maybe your diff is a little melted/deformed or the O-ring is fused to it? Push it out, man. Or pull it from the outside. If the sun gear pin is out it should be able to be removed.i got the pin out before but i’m talking about it coming out even with the pin out it’s not wanting to come out
That is a sail jib, idk wut these guys are talking about.Still trying to figure out what a jib is. I just Googled it and says something about a triangular boat dohicky. Here I am lost again!
I'm just tired of being confused! I need to be De-confused!That is a sail jib, idk wut these guys are talking about.
I just had this happen tonight. How did you sand the shaft?I get a hammer and something slightly smaller than the input shaft and knock it out. Then I'll sand down the input shaft so it slides in nicely
