blakeaowen15
here’s a pic of what one in need to replace
There's a gear on the bottom of that cup. Pull out that gear & pull out the pin that goes thru the shaftView attachment 277700i need to replace this outdrive on my diff, and i can’t seem to find anything on how to remove it, anyone know how? men is dumb so if you have a response could you please hit the reply button. sorry guys im picky
i did remove that sun gear( it split in half during my previous bash) and even with that sun gear out it doesn’t go throughThere's a gear on the bottom of that cup. Pull out that gear & pull out the pin that goes thru the shaft
Remove the grub screw from of the diff case and take the pin out through that hole.i did remove that sun gear( it split in half during my previous bash) and even with that sun gear out it doesn’t go through
I did that alsoRemove the grub screw from of the diff case and take the pin out through that opening.
yes but for some reason even with the pin out i’m pulling on it as hard as i can and it won’t come outThe pin is holding the diff cup in, so without the pins you should be able to pull the diff cups out.
