Put a 3mm hex driver behind the sun gear and hammer it. Might have slightly fuzed with threadlockTrying to separate the pinion from a damaged front gear box. I removed the grub screw but can't get it budge, am I missing something? I looked at YouTube but can't find anything clear enough showing the process.
Take an awl or suitable size punch, heat up the Input cup , then punch out the Pinion/input gear through the Input cup. Easily done with some heat/ mini torch. They usually get stuck like this. Use Blue Thread locker on the Cup's set screw/grub screw when you reinstall it . Let cure for a day or so, before running it.Trying to separate the pinion from a damaged front gear box. I removed the grub screw but can't get it budge, am I missing something? I looked at YouTube but can't find anything clear enough showing the process.
