Kraton Hot Racing Wing Mount
Sully_
Anybody use a hot racing wing mount? how often do you break your diff case having less play in the wing mount ? i just picked one up, hoping that i didn't make a bad purchase. Only after the fact did it dawn on me that it may put extra stress on the diff case.
All depends on what you use your car for. I figure the aluminum HR wing mount as a speed run part. I can only imagine it will bend all out of place during the first heavy bash. I like to do cart wheels too much for that thing to last, more than a day on my car. The plastic one it came with has always just bent, but never broke.
well poop. lol. guess this ones going back to tower. Thanks for the input guys :D
In case you are looking for what you want to spend that extra cash on.....
So far, I have and would recommend the following HOT Racing Kraton Platform Upgrades
AON1101 Aluminum Differential Carrier Case
AON38A01 Aluminum Center Differential Mount
AON38C01 Aluminum Center Differential Brace Gear Cover
AON21M01 Aluminum Steering Blocks Hd Bearings
AON22M01 Aluminum Rear Hubs Hd Bearings
AON4801 Aluminum Bearing Steering Bellcrank
AON311M01 Aluminum Center Sway Bar Mounts
AON28C01 Aluminum Front Chassis Brace
Not saying the motor mount, servo mount, shock towers, Fixed Link Steering, and gear boxes/bulkheads aren’t decent upgrades, I just don’t have them.
I got my shock towers and steering rack from Voltage and my servo mount from GKA. Those 3 parts are so solid I would have a tough time recommending anyone else, for those.
