Think there is any need to change the servo in the new Notorious?25kg amazon servos have never failed me. 25$ canadian.
The amazon servos come with a metal servo horn.If it’s a V5 and you’re upgrading to the 25/35 kg Amazon/banggood servos, don’t forget to pick up a 25T servo horn.
When it breaks, unless you want a faster more powerful servo right away. There will be a noticeable difference. 15KG with that stock "analog" servo is lame IMHO. I even tried it in my Crawler and it got eaten up real fast. I gave Savox a try. Wasn't happy with 2 1210's. I currently use this 35KG Digital coreless DSS servo with great results in 3 of my rigs. But I am critical of servos when I spend alot of $$. When they are below $40. I can just dispose of them and not look back. Generic brand servos last as long or much longer than some $Brand$ name ones. Everyone has their own taste. I like 35 KG for hard bashing in heavy rigs. I use 25 Kg in my Lim.(much smaller wheels)Think there is any need to change the servo in the new Notorious?
https://www.amazon.com/gp/product/B07SBYZ4G5/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
kWhen it breaks, unless you want a faster more powerful servo right away. There will be a noticeable difference. 15KG with that stock "analog" servo is lame IMHO. I even tried it in my Crawler and it got eaten up real fast. I gave Savox a try. Wasn't happy with 2 1210's. I currently use this 35KG Digital coreless DSS servo with great results in 3 of my rigs. But I am critical of servos when I spend alot of $$. When they are below $40. I can just dispose of them and not look back. Generic brand servos last as long or much longer than some $Brand$ name ones. Everyone has their own taste. I like 35 KG for hard bashing in heavy rigs. I use 25 Kg in my Lim.(much smaller wheels)
I said the same. I don't know how Savox can compete at $70.+ for theirs. I have 3. The oldest is like mos old. I may use it in one of Crawlers next.
35 kg is like 486 in. oz. of torque. You can never have too much torque when it comes to servos. They hold up much better. Crawlers eat underpowered servos because you are stalling them under load and burn up. Very different than bashing. Did you ever temp check your servo. Most don't, but they get over 100+ F easily.
Edit: It comes with a nice alloy clamping servo arm. That's worth like $12 right there. Useless fit in an Arrma 6S rig, but works out great in one of my Axial Crawlers and even my Tekno MT. Servo arm has been in my MT for 3 years now. Attached to a Savox SA1230 higher end servo. Not WP though. I WP'ed it myself with Silicone conformal coating. This Savox is actually a great Track servo. It better be at $95. when I purchased it 3 years ago. But I am done with Savox and Futaba.
Not yet knock on wood.@slick2500 did you ever had one die on you?
I had one of those in my Outcast, the top of the case broke where the gear shaft rode inside it, it's hard to explain without a picture but inside the top of the plastic case is a little hole that the shaft the gears are on ride in to keep the gears centered, that little hole broke in there, was probably a fluke but for $12.99 it worked great before it broke.I’ve killed one of these in my Typhon 3S:
But so for all of my DS3225 25 kg and SPT 35 kg servos are doing well
