- Illinois
- Fireteam
- Infraction
- Limitless
- Kraton EXB
- Talion
- Typhon 6s
- Typhon TLR
I did my first ever speed runs this morning and I am hooked! I'm excited to see how changing the car will affect speeds. My current goal is 100 mph on 3S.
Run 1, battery 1, 1135 ft: 72 mph
Run 2, battery 1, 1100 ft: 71 mph
Run 3, battery 2, 1215 ft: 73 mph
The car tracked straight. Since I have the perfect pass, I just hit full throttle from a stop instead of feathering.
Considering the motor temps were so low, it seems like I simply have to gear up. Do you agree? Any concerns with the amount of voltage sag or anything else in the log or setup?
- Limitless V1 with 32p/30s gearing
- XLX2 (timing 0, punch control 80%)
- 1515 2200kv motor
- CNHL 3S 9.5ah 90C
- Perfect Pass launch control (max setting)
- Outside temp was 45F
