Luigibell78
- Limitless
- Outcast 4s
- Typhon TLR
Good info...?Hey Kevin, since you are reading this anyways.
Come on dude! I tested that foam burns within 8s. Rubber tire takes much longer to start burning like that. So I make a remark in your defense and that's the line pick to mention?
Sad to see what happened with the second ESC. But with a scientific hat on, i am impressed how you filmed it this time. I take back my initial response to the videoKevin is not the best point of reference imho
You have proven that the xlx2 can definitely not deal with that motor / voltage combination.
The hobbywing has hard limits on amp draw and has a hold back when exceeding it's rpm limited. That's why the max6 is faster as it's rpm limit is about 40k (8S*1200kv) whiles the MAX5 has a limit of 33k some margin (8S*1000kv). I assume it's managed by software.
The XLX2 supposed to have 'no determined limit' on rpm limit. Now it has...
How about pulling up the no load specs of the tp motor he is running?. If it's more than 5-10 amps i would be surprised. There is definitely little to no load on kev's second test run.
The xlx2 can't handle a split second run of a few amps....seems kinda strange and it's nothing he is doing but rather a hardware compatibility issue.
