Accidentally overcharged a lipo to 4.4volts/cell. What to do?
Germany
  1. Senton 3s
The charger issued a connection error on channel A when I came back. So could have been a dirty balance plug, at least that's what I read on a different thread.
Well the charger decided to charge to almost 4.4 volts. The B channel had the correct 4.17volts just like I wanted.
I immediately discharged the lipo with the RC car. So the battery was 30-60minutes above 4.2 volts.
Is that lipo save to keep? No swelling yet. I recharged it properly and drove the car a little on 8s and everything looked normal.
https://electronics.stackexchange.com/questions/317717/how-much-can-i-overcharge-a-4-35v-lipo
Quote:
So, overcharging of 150 mV over the nominal 4.2 V leads to about 10% more capacity for first 50-100 cycles, but the service life shrinks from 500-1000 cycles to about 200. Extrapolating, the another 100 mV will result in maybe 30-50 cycles life. This means that 50 mV over the spec won't kill the battery.
I wouldnt worry, but that cell took a beating on terms of cycles.
Bring it back to a safer level ASAP i.e. use it. Move on with life, maybe took 5% of lifetime life out of it but ok to use.
Around 4.5 - 4.6V they will catch fire and you'd be posting a 'burned down house' picture.
Watch them!
