We got 5-6" of snow Friday night and now the temps have dropped out.
I'm jonesing for some wheel time. So much so that I'm doing some nitro maintenance.
Pulled the engine on my Savage X to gear it down a tooth on the bell to find that my engine mount was broke. Got a new one of those installed and ARO'd the engine/seals with the new bell.
Then decided to pull down my 21TM revo to check shock end slop and drop it down a tooth as well, ended up going up 2 teeth on the spur instead. Used dubro monster ball ends for the rear shocks, hoping they hold up better. Also ARO'd the engine/needles as I'm pretty sure I forgot to do that when I ran it this summer. Found the header gasket was torn... had a hard time finding another to fit with the THS high torque pipe/header. Found a random one in my parts box, I think it was an associated one that apparently is discontinued. Ordered 2 more one ebay to have on hand.
Now I have my big block revo on the bench, rear shock ends are trashed and just found that I have integy P1 rockers on the rear and can't find a good set of captured P2 aluminum ones, so ordered a set of not captured HR ones. Also put dubro ends on the shocks. Waiting for the rockers to show up and trying to figure out something better for the header. I have the THS BB revo pipe, but it's header is twisted/bent to fit a standard traxxas BB mount, so I had to make something out of an LST2 header that works, but pretty sure it doesn't flow well... I ARO'd the engine, but can't put it back in until I replace the rockers.
Outcast, stampede 4x4, ejato, savage flux are all ready to bash...
I've read/seen quite a few posts where arrma esc's aren't fans of water, even though they are supposed to be waterproof. I haven't run my outcast in snow yet, at least not enough to get it all under the body. Is it a hit or miss thing? Some are ok, others aren't?
