Greengaunja
Ise da by' dat burns da Senton........
ArrmaForum Fan
- Durham Region, Ontario Canuckistan
- Senton 6s
- Senton 3s
Last i went looking for a solution to my own problem. My XLX2 is beeping start fail. Its never had BLink installed but one solution i found in another thread was to use Link to reset to defaults. However, i do use the Aux for throttle adjustments. But it's wired right, has worked for almost two months of testing and calibrating. Yesterday I was supposed to try a real speed run and test the foams I have for it. Had a buddy tag along to film it all, we get to the spot, hooked up batteries, watched the initialization, put the body on and gave her light throttle to peel off to the starting point. Except she didn't peel off and I get the two short beeps. No explanation for it, the only thing different was changing GRPs for GT8s.
*Wired correctly.
*Wires are good and snug.
*Only interference with drivetrain is the motor(none now with pinion off)
*Radio has signal and servo responds as it should.
*Rx and Aux wires are snug and in channels 2 and 3 respectively.
Straight outta ideas and hoping the reset works.
Ok, I think I'm in trouble...
I'm getting a green square for both USB connected and device linked. Yet the Link is flashing red/green(should be solid green). After a minute I get this:
I follow the instructions and it's the same thing over again. If I FUBARed this esc, it would be nice to at least know how I managed that.
Sorry for the repetitive post, but the pocket protector spotlight over Gotham didn't work on the other thread.
*Wired correctly.
