So i just installed the rotolok motor mount. I am unable to use my stock center differential. The bearings seem too big. any suggestions?
I got it now. Just had to use some good ole pressurePost pictures, that helps a lot. I’ve never heard of anyone having an issue with one.
Would that not make it too short for the pinion gear to reach?Flip the diff 180°
I should be able to pull the pinion out a little bit. if that doesn't work, i will have to flip it.How are you going to get the spur gear to make contact with the center diff/pinion?
I see. I've never used a scorched piece like that, so I was just wondering. I use PPS on my rigsI should be able to pull the pinion out a little bit. if that doesn't work, i will have to flip it.
I have seen very good things about the PPS mounts. I just decided on scorched because it looks differentI see. I've never used a scorched piece like that, so I was just wondering. I use PPS on my rigs
