blaster27
Military Veteran
ArrmaForum Fan
Rig of the Month Winner
Have to add a valid message.
That is too funny.We have tried 3s on 6s rigs, it does work but....
If you have matched 2s and 3s batteries you may be able to use them in series (4s and 6s).
ok that's great to know....i'll probably just get some batteries whenever I have the money saved up to buy everything....that's being said....
what batteries do ya'll recommend for the Typhon 6s? I really hate having to change batteries every 10-15 minutes. I'd rather just get something that will run a good amount of time.
Are there any major pros/cons to using two 3s batteries in series over buying one 6s battery?
ok thanks for the detailed response....So your pinion was loose (grub screw loose) and also way worn out. It is a normal wear and tear item.
The second video, that play is mostly normal but what I see right away is some up/down movement which means your bearings are toast or something else is causing that movement.
Sealing the power module helps reduce wear on the pinion/spur/bearings/motor bearings.
Nothing wrong with running them on 3s .just a bit slow and under powered.We have tried 3s on 6s rigs, it does work but....
Typhon 6s then u have best of both worlds,u can bye kraton hubs ,bigger tyers keeps it off the ground or u can speed run,it's versitile little carOk so I had 2 different Typhon 3s's, and I loved them, except they kept breaking so I finally gave up. The first one I had kept going into low power mode, so I exchanged it for another one. Then the second one stripped the spur gear after the 3rd time. I installed an Arrma branded metal slipper clutch assembly, and then after a few runs that stripped my pinion gear. I got fed up and returned the car last week. I want to clarify, I'm not doing anything wild with these cars. I simply like ripping them around my local park once a week. No jumping...just flinging dirt around and going fast in big circles. That's the extend of the abuse. Arrma's support wasn't very helpful at all with either of these situations...so I was going to give up on Arrma, but I decided to forget that since I really like the Typhon. It handles awesome and it's so fun. So should I
1. Get another Typhon 3s and build it up to not break every time it's mildly windy...
2. Get a Typhon 6s and run it on 3s or 4s (essentially never abusing the car since i'm running it below it's potential)
3. Or should I forget the Typhon or Arrma cars altogether and try something else...
I just want something that isn't going to break constantly. Since I'm not doing anything wild with it, I kind fo expect a high quality "indestructable" RC car to work most of the time...or am I simply dreaming? I'm new to this hobby, but I do have 2 Hyper Go cars that seem like they are impossible to break. I figured the Arrma car would be even better.
Does Toyota make RC cars? haha..
thanks in advance...
I just noticed that you have a cat eye light on the front of your car..haha..that's awesome..how does that work for ya?Typhon 6s then u have best of both worlds,u can bye kraton hubs ,bigger tyers keeps it off the ground or u can speed run,it's versitile little car
The larger tires will just wear out your 3s Typhon that much faster. . 6s will be very tough.yes I was actually planning on doing something similar with my Typhon 3s before it broke again. I know with the Typhon 3s that Proline Trenchers 2.8 tires will fit on it without any modification...is the same true for the 6s? if so i'll probably just grab those tires and put them on whenever I want to rip through some taller grass or whatever..
Its a bike light works good red one on the back .lolyes I was actually planning on doing something similar with my Typhon 3s before it broke again. I know with the Typhon 3s that Proline Trenchers 2.8 tires will fit on it without any modification...is the same true for the 6s? if so i'll probably just grab those tires and put them on whenever I want to rip through some taller grass or whatever..
that's a good idea...how do you have them mounted? and are they just battery operated or did you wire them in some how?Its a bike light works good red one on the back .lol
Batt oppthat's a good idea...how do you have them mounted? and are they just battery operated or did you wire them in some how?
Oh okay the Hoonitruck vibethat senton 6S is givin me Hoonitruck vibes.
And they're good vibes.
