SrC
RC is a lifestyle choice
Hospitality Award
- Queens, NYC
- Fireteam
- Infraction
- Limitless
- Kraton 6s
- Mojave
- Notorious
- Outcast 6s
- Typhon TLR
I was using The Original Legit Deans plugs 30+ years ago. It was the best at the time that the Pro racers used. But there was NO Lipo tech. back then. And Only Brushed ESC's, motors and Nim/Nicad packs. Racing only 7.2 volts at that.IC5 and EC5 connectors seem to work mix good together atleast for me.
XT90 to EC5/IC5 well maybe on 6S power, I melted together both connectors with ESC XT90 to 2 4S batteries EC5 on a run with 7000mah 80c Outcast 8s exb 800kv hobbywing Max5 39:39 hard/high speed amp draw.
Deans seem to have a rating of 60 amps, its to low to be safe with 6s and 8s under all circumstances, its just a bad idea on anything above 4S that draws massive amounts of amps like @SrC said.
>>>The Deans Patent expired some years ago, and now what you see today are not even legit Deans. Just very cheap Knock off generic copies at that (often called T-Plugs to Avoid using the Deans Name), and are just Not good for ANY Lipo setups these days, IMHO.
T-Plugs are horrible with any BLX setup, no matter the volts you are using. Been there.
They equate, spec. amp wise, to running the smaller XT60's, which are way better for smaller 2s 7.4 Lipo packs. What the Drone/Quad RC crowd run these days.
