- Maryland
- Infraction
- Limitless
- Mojave EXB
- Senton 3s
- Talion
- Typhon 3s
- Vendetta
Yup. Before yesterday my fastest runs were 204-205 with my orange vte2.Hot damn! 208mph is moving. Is that a PB?
Thanks buddyThat's awesome brother!
World's fastest typhon grom, 3 passes today with a damaged front diff which broke on the last run and went off road and up a palm tree,lol.We finally have our very own speedrun section so,
Let’s see ‘um
Post up your daily MPH and/or new PB numbers here.
You running a spool? Gearing?? Kv?So close.... I know, no video. I will maybe do that after I get the hold of things. View attachment 363309
Vendetta on 4S
Yep, HR spool, 30/34 MOD1, TP3650 3050kv or 3080kv?. Mmx8s. HR metal diffs, stock yokes. (Bought the HR yokes, but felt they where too sloppy) and GPM driveshafts.You running a spool? Gearing?? Kv?
I have a Infraction I want to push it to 4s
Did you go to a aluminum center driveshaft?Yep, HR spool, 30/34 MOD1, TP3650 3050kv or 3080kv?. Mmx8s. HR metal diffs, stock yokes. (Bought the HR yokes, but felt they where too sloppy) and GPM driveshafts.
Not yet. Still stock.Did you go to a aluminum center driveshaft?
What is that car?I can almost taste it...
Finally first run of the season, felt good to be back out and getting some passes in. Need to break into the logs and see what's going on inside now that's I've got the MMX on board. And this TP motor rips!
Let’s see ‘um
The fastest typhonhttps://youtu.be/rb_6M8nnKGU?feature=shared gromWe finally have our very own speedrun section so,
Let’s see ‘um
Let’s see ‘um
That's awesome for a little truckStarted taking my Omni terminator truck to my spot with my other speed run cars and what do you know, it has become part of the squad! It started out in the 50s, second outing it hit mid 60s and this video is the third outing with it. I'm going to keep pushing it of course!
The spektrum 130a escs surprised me with how capable they are. With an almost identical motor and that esc I was able to hit 88mph on my Bullet, and that's bigger and twice as heavy, so it definitely has some potential to take that little truck higher!Started taking my Omni terminator truck to my spot with my other speed run cars and what do you know, it has become part of the squad! It started out in the 50s, second outing it hit mid 60s and this video is the third outing with it. I'm going to keep pushing it of course!
Yeah, I'm happy with the esc also. 88mph is nice! What ended up happing to yours? Did it start cutting on you or did you fry it? Know cutting for me yet but I think I'm just getting to the point where it's starting to heat up and might start to cut soon!? I had a 26t pinion on it in that last run so next time out I think I'm going to try a 28T.The spektrum 130a escs surprised me with how capable they are. With an almost identical motor and that esc I was able to hit 88mph on my Bullet, and that's bigger and twice as heavy, so it definitely has some potential to take that little truck higher!
I probably could have squeezed out more with smoother, longer trigger pulls, but I was running into road length issues beyond that. Interested to see where that 130a can take you!
