Lol, Yeah I guess clipping and carting wheeling don't help things. Any shocks you recommend off amazon?Define “more durable” because when I smash into things, something is always breaking. Once I stopped clipping mailboxes and cartwheeling, I haven’t broken a stock shock in a looooonnnnng time.
I vote stock. If you “upgrade” there is still a good chance of breaking a shock and if you don’t break the shock, you may end up tearing out the shock tower cap where it mounts.
I looked at that thread...but it didn't seem to provide any solid links to products online. The shaft snapped and the spring was no where to be found.Where on the shock did it snap?
You mentioned there were a lot of options, and there are, but hopefully this thread will help you narrow it down. Keep in mind that you'll want to check out the section "Arrma Vortekz 4x4 BLX" in blue of the first post. Depending on where the shock snapped, you could opt for the aluminum version of the stock shocks, Pro-line's Powerstroke shocks (expensive), or Felony/Limitless/Infraction shocks for the front and 6s shocks for the rear.
@Velodromed also set his 3s rigs up with some aluminum shocks in a slightly different manner, so I'll let him explain (as he's the resident 3s expert).
Yeah, seems very broken. Duct tape will totally not fix that. Many of us like the 6s shocks on the 3S cars… but it’s a kinda expensive investment so you have to really be into your 3s car. But if that is something you want to explore, were more than willing to help guide you on it.
Would be interested to hear about it and the cost. Got some pictures of the cars with 6s Shocks on it? Main reason I got the cars was I wanted something fun for them...and if they break a part...should be easy enough to replace. Right now my little girls are just learning...I am assuming they are going to get beat up pretty good... By my 9 and 11 year old girls. They both have their own Vorteks, just different colors. I have already added M2C Racing -M2C 3450 ARRMA 3S SWB CHASSIS BRACE VORTEK / GRANITE - https://m2cracing.net/shop/shop.php...VORTEK-GRANITE/p/496059337/category=136155254 (For both cars) Figured it would help with durability.Yeah, seems very broken. Duct tape will totally not fix that. Many of us like the 6s shocks on the 3S cars… but it’s a kinda expensive investment so you have to really be into your 3s car. But if that is something you want to explore, were more than willing to help guide you on it.
That is typical. Just user error. It happens. Replace with another stocker set from JennysRC ( cheapest alternative) and she will keep rollin. Parts will break. Fix and repeat. No need to always drop more $Coin$ trying to avoid the inevitable, user error. Doesn't alway solve the problem. Just empties your wallet faster. A personal call.
Got both Cars on amazon for a great price $310 each with tax..so putting a little back into it is not horrible. Batteries and chargers hurt a little although. Also bought BatSafe box to keep my house from burning down on accident. Totally get that this hobby can drain the wallet fast...lol.That is typical. Just user error. It happens. Replace with another stocker set from JennysRC ( cheapest alternative) and she will keep rollin. Parts will break. Fix and repeat. No need to always drop more $Coin$ trying to avoid the inevitable, user error. Doesn't alway solve the problem. Just empties your wallet faster. A personal call.
Sold out right now.
But they get them in almost every week, usually posted on Fridays. They are inexpensive.
https://jennysrc.com/collections/ar...rings-senton-ara4305v3?variant=39407339208758
Changing out to different shocks will always change the handling slightly and might have to be dialed in. Going with the 6s shocks as stated above would be the next best option.
Links work just fine on my end.Lol, Yeah I guess clipping and carting wheeling don't help things. Any shocks you recommend off amazon?
So the Traxxis shocks work on the Vorteks?Links work just fine on my end.
Only thing is that the rears might be a little short.
Traxxas GTR Shocks.
Get VG Racing springs. https://www.vgracing.com/product/GTR_Springs.html
Fronts 87mm eye to eye https://www.ebay.com/itm/274394584293?hash=item3fe33114e5:g:KS0AAOSwSWde4oZc
Rears 103mm eye to eye https://www.ebay.com/itm/192771284109?epid=1203434569&hash=item2ce2105c8d:g:ksYAAOSwgYBggyYs
Proline PowerStroke shocks for the Slash.
Fronts 88mm eye to eye https://www.prolineracing.com/performance-parts/power-stroke-shocks-front.asp
Rears 102mm eye to eye https://www.prolineracing.com/performance-parts/power-stroke-shocks-rear.asp
Proline Pro Spec shocks for the Slash.
Fronts 88mm eye to eye https://www.prolineracing.com/performance-parts/pre-assembled-pro-spec-shocks-front.asp
Rears 100mm eye to eye https://www.prolineracing.com/performance-parts/pre-assembled-pro-spec-shocks-rear.asp
They will bolt on but the rears are a bit too short. I would have to check the length of the other Proline shocks. Beyond that I'm not sure as I don't have a Vorteks and I have no plans on buying yet another flawed 3s model until they fix the motor module issues.So the Traxxis shocks work on the Vorteks?
Interesting what issues are with the motor module?They will bolt on but the rears are a bit too short. I would have to check the length of the other Proline shocks. Beyond that I'm not sure as I don't have a Vorteks and I have no plans on buying yet another flawed 3s model until they fix the motor module issues.
6s mojave front shocks work great on the rear of the vorteks. I tried a few different shocks for the front before I gave up and put a granite shock tower on the front end so I could run the Mojave front shocks all the way around. It does jack up the front in a bit though.They will bolt on but the rears are a bit too short. I would have to check the length of the other Proline shocks. Beyond that I'm not sure as I don't have a Vorteks and I have no plans on buying yet another flawed 3s model until they fix the motor module issues.
Dirt gets trapped inside the motor module and wreaks havok on the bearings in the motor and slipper. I got sick of replacing mine every 3-4 runs so my 3s models just sit. There are a few band aide fixes floating around but nothing helped on my end.Interesting what issues are with the motor module?
I saw something about this on youtube. Looked like most people either taped it off or one guy used the fuzzy side of velcro on the edges of the box. Would seem like it should be a easy fix...wonder why the company left this box open to begin with?Dirt gets trapped inside the motor module and wreaks havok on the bearings in the motor and slipper. I got sick of replacing mine every 3-4 runs so my 3s models just sit. There are a few band aide fixes floating around but nothing helped on my end.
Oh nice, the Mojaves seem like that would be awesome on the back shocks. I just ordered6s mojave front shocks work great on the rear of the vorteks. I tried a few different shocks for the front before I gave up and put a granite shock tower on the front end so I could run the Mojave front shocks all the way around. It does jack up the front in a bit though.
