Yazman
I've been snow bashing my Xmaxx, Noto, and Maxx, and I've been trying to take really good care of them. I have a dust cover for all of them, and I spray down the entire rig (minus electronics) before bashing with silicone spray. Afterward, I dry the whole truck with a towel and hair dryer, then spray a very liberal coat of WD-40 all over everything (minus electronics) and let it dry.
I thought everything was cool, until I broke the front upper bulkhead on my Xmaxx. When I opened the rig up, I found that every single space was invaded by WD-40 and dirt. A bunch of bearings were scratchy and the outside diff housing had water and junk in them. I ended up tearing apart the entire Xmaxx and soaking all the bearings in alcohol/simplegreen mix. I'm also working on spraying and wiping down everything with simplegreen. I've bought some marine grease for the outside of the diffs.
I read so much conflicting information--don't use WD-40, use WD-40 but only after running, use carb cleaner, don't use carb cleaner, use water to wash your rig, don't use water. You get the idea.
I'm a noob trying to take good care of my stuff. My Xmaxx is in a million pieces on the floor, and I'd like to avoid this again for as long as possible. Advice is much appreciated.
