I saw a you tube video that used 3s. It's working. But I have a problem that the run time may reduce due to temperature.No. It will take up to 2S lipo with the jumper set to lipo mode.
The ESC is not rated for 3s. You will fry it and the motor. But have it since someone on YouTube did it ?I saw a you tube video that used 3s. It's working. But I have a problem that the run time may reduce due to temperature.
Yes you, the Youtube Mega Star should know better. If it's on Youtube, it's true!The ESC is not rated for 3s. You will fry it and the motor. But have it since someone on YouTube did it ?
