Saltystevo
So I'm not sure what's going on but my stock servo worked better then this savox! And turned allot more too! . It seems like the servo is cutting out under load or seems really under powered.
How is that possible?
Is also making a whinning noise until I move it a little bit. With it off and gently moving it, it sounds gridy around it's home position. When not moving but in grass the wheels (back flips) were struggling to turn. Actually they barely turned in one direction and about 70% in the other direction, it was horrible.
Here are the details:
Not using a glitch buster.
Installed ground wires on esc and servo to receiver on the right side of receiver
I temporarily installed it into a stock mount.
I programmed it to turn as much as possible before the servo saver starts to lift and or split.
I installed it with the supplied rubber grommets but didn't add the metal tubes that go through them.
I used the arrma spacer as well.
Hub nuts are set perfectly.
Do you guys think I got a faulty savox?
Or?
Any ideas are appreciated!
Or?
