Kraton Roll cage problem!!!
I installed a new hot racing motor mount and new hot racing center diff mount and new hot racing gear cover. Will I be able to fit the roll cage I’m having trouble getting it back on. Is there a way to do it??
It fits right over the top
.....if you haven't bought this as well, you should....
https://www.ebay.ca/itm/40293331151...RupdolpyZxBTW4fq0aYX6VEceIhNAkAgaAh8WEALw_wcB
Where did you get the
Where did you get the fans.
power hobby dual turbo fans amazon
Right on top
Does it work w this style motor mount I just thought about it. This motor mount and center diff mount might be for the Typhon
I can’t answer that for sure, but I assume it would fit on this motor mount. The 6s line carries common mount sizes.,,,,,Kraton outcast, Talion, Typhon, so the HR mount you are using should accept the diff cover the @Rcproponent mentioned above.
cheers,
kev
cheers,
kev
Thanks I guess I’ll find out in a few days
That is the older style (V1-V3) motor mount that you bought so no the part that @Rcproponent linked to will not work with it as that part is for the newer style (V4+) motor mount https://hot-racing.com/?partnumber=AON38F02;c=926 The part that @KevinC linked to will not work with that mount either.
Ok I’ll order that motor mount or just use the stock mount and new diff mount. Thanks for the input I was waaayy off lol. It’s a learning curve.
yeah it could also work on the Typhon 6s because it’s less bulky so I might switch this to Typhon since it doesn’t have a roll cage. If im not bashing the kraton too hard do I need The roll cage
