Rlaarlo speedrun
Jester194
Connecticut
  1. Talion EXB
  2. Typhon 6s
So I've already mentioned I hit 94 mph. I am putting on a 45 tooth pinion tonight, it has a 40 now, do you guys think that will be enough to break 100 or should I just try running 4s instead of 3 that I have been
I’m sure you could hit 100 on 4s. What setup is it? You should post this in the Speed Demons section. Lots of guys will chime in. @vwturbowolf hit 181 with his Rlaarlo.
https://www.arrmaforum.com/forums/speed-demons.63/
I have stk gearing with the rlaarlo 40 tooth pinion.. castle mmx8s with 1412 6400 kv motor and all lighting and extra wires and weight removed
Should I try just 4s or do you think I should put 45 tooth pinion in also.. 100 is my goal for now
Try 4s and see what you get. You may only have to go up a couple of teeth to get where you want it.
