Radiolink RC8X
What did you discharge them down to? 3.7V, 3.6, 3.5V? This is ~ 77% ) which would be expected ~ 3.7V roughly 80% of the usable charge.
Just curious. Will probably check mine as well.
Good question! Went down all the way to 3.0V.
@Mike-h yes correct. In fact jkflow mentioned it, you probably want to stay close at around 3.7V per cell.
3.0V is the lowest I would go only when testing for full capacity. For science!
PS. Wouldn’t ever do this on my SMC packs 😊.
Getting similar results on my lipo.
Discharged to 3.5V (~0.6A load), recovered to 3.6V (this is at best 20% of rated capacity) and by all means anything below 3.5V is not usable.
Boring math:
20% of 2800mAh = 560mAh i.e. I should be able to refill 2240mAh. I got 1940mAh.
So basically it's a ~2500mAh pack. That is outside the industry standard of 5% error on marking.
Volt vs capacity
https://www.hyperion-world.com/en/blog/view/post/a-guide-to-lithium-polymer-batteries
