Kraton Question for community on Motor KV in a Kraton ?
Big Kid
Old Hangtown .... USA
I'm building up a Kraton 6S chassis using mix & match parts/pieces. See: Kraton custom
Standard straight cut gear diffs F/R and a 50T on Center ... standard stuff.
Will be running on 4S "Only"
Wheels @150mm Backflip LP's
Spur 12-13-14t range in hand.
Question ... Can my 2350kv 4268 motor work with this rig ... or is it to high a KV ?
I do have a OEM 2050 4274 on hand as well :sneaky:
2350kv 4268 is not too high for 4s, even 5s, you're pushing it off road with 6s though. 14 tooth might be a bit conservative on 4s, would be good on 5s. 2050 4274 would be better for 6s.
