Installed
They're definitely progressive rate springs. They have to be. That's the only way they can be soft under low compression and then go stiff as a wedding when you go past a couple of mm. Looking forward to getting mine. They won't be here til middle of April but that's fine. Weather is still an ice cream ing taco here.
Pretty amazing that these springs can mitigate bad car setups and bodies with poor aerodynamics:
Only teasing of course, I hope this does help people. In general the perfect pass line of products has been great so far and I would assume these are also. My prediction is that the front springs are considerably softer than the rear, which will be hard as a rock.
Yes all of the above and Disney Magic too.What's the dealio with fancy springs? Are they just a size and rate that is otherwise not readily available, or is there some new mystical nano-technology in them?
It's a great price point. Joe Diaz springs cost me $50 and, not having used these PP springs yet, I'd be willing to bet a month's salary that these will be superior in every way.They seem very reasonably priced for front and rear springs. But I've already setup mine to mitigate back flips and blow overs. Maybe on the next one.
I swapped my front springs (38lbf/in) for the stiffest factory springs I can find and also added "bump stops" to the front. It's got the proper rake and doesn't drag the belly on the ground anymore.
They're not really "fancy" per se as progressive rate springs have been around for ages but, until now, no one had mass produced them for the Arrma 6S vehicles. The stock springs were fine to about 85-90mph but anything beyond that required making more invasive modifications to make them work. Stiffer springs became available at some point but those didn't really seem to address the actual issue people were having as speeds went higher and things like blow overs and other suspension induced crashes got more and more expensive. The speed running scene found solutions but they always felt more like band-aid solutions as opposed to addressing the underlying issue. If these do what they say on the tin (I have no reason to presume they don't/won't and say there's not a chance in hell that Raz would release these if they didn't...he has a reputation to maintain and protect and, if you were to do one last scam on your way out of the scene, you're most definitely not going to be doing it with a $35 set of springs) then I think the actual problem and underlying issue now have an actual solution.What's the dealio with fancy springs? Are they just a size and rate that is otherwise not readily available, or is there some new mystical nano-technology in them?
Possibly. Or perhaps variation in how the metal is treated on different sections of the spring to increase/decrease stiffness, springiness and whatever other characteristics it can have that are relevant to how a spring performs.Yes all of the above and Disney Magic too.
If you watch Raz's video he says they are progressive coils. However, most progressive coil have variable coil spacing. Not Raz's Spring.
Maybe the springs are thicker diameter on one end?
I'm not a big fan of locking out suspension (infinite spring rate) because it transfers all the stress to the chassis and makes for an ill handling car on a less than perfect road and the care can skip. Maybe this will be good compromise between too stiff and too soft. They are the Goldilocks springs.
Indeed, my rear springs would hop. As can be probably seen in some of the V1 and V2 runs. I should have some more videos that have never been posted on YouTube, but I’m hoping that these will fix some issues… especially with the the rubbing of the dog bones and CVD before hand… didn’t brand. I’ll post some pictures of them. But if I can ever stop being ocd about the new build. I’ll be able to test these outYes all of the above and Disney Magic too.
I don't get it...who was this for?
Me too. I think I have the first gen on the build I’m doing now. Good to know what you said about the second gens. I was going to run them in an upcoming build.We shall see, I’ve been using @RedondoBeachRC
I have a set of PP’s coming. Like @LibertyMKiii said, I’ll probably still run limiters, at least in the rear. But if these new springs really are “all that” or even “half that” you sure can’t argue about the 37.00 price tag. I like the color, too. Almost a Ti look.
Mighty nice of him to offer these springs at cost as a “community service” to help us in our quest.
That’s great feedback. Mine are out for delivery as we speak, I’m really interested in trying them. Going to take off the @RedondoBeachRC springs (which I really like) and put the PP springs on this build to check them out. And yes, a little more suspension would be appreciated!I question the removal of the limiters at first; but upon installation and pushing down on the car; the car completely stops before it gets lower than the front; given the front ride height of my car is set at about 6-8mm. It really is incredible; whats good now is that I can remove about half of the preload I use to have on the rear. Allowing better suspension travel within the first few mm of travel.
I have to say I am quite impress with them and waiting for better weather to give it a go.
Yes to what you're saying. I just put another set on my other limitless. I just bought some fuel line but I don't no why it would even be necessary with these springs. I am dying here waiting for someone to test them out.I question the removal of the limiters at first; but upon installation and pushing down on the car; the car completely stops before it gets lower than the front; given the front ride height of my car is set at about 6-8mm. It really is incredible; whats good now is that I can remove about half of the preload I use to have on the rear. Allowing better suspension travel within the first few mm of travel.
It's a special orderAny chance they make them in red ?
Thank you but I have tons of paint .was hoping the springs would already come in red by manufacturer
