I bet it does!! Gotta be bonkers!? Can't wait to see the vid! Must be counting backflips on a slo-mo replay?the 800kv 56118. XRT flips faster than my kraton 6s, its bonkers
FPS= flips per second!!
i'm still a pansy tbh. I did manage to man up and do a double flip the other day though. It was GLORIOUS! especially when you factor in my jumps are more distance than height.I bet it does!! Gotta be bonkers!? Can't wait to see the vid! Must be counting backflips on a slo-mo replay?
Had that in the XMaxx. The rear diff kept eating teeth when jumping. Needed shimming internally. Not just one shim. As far as I remember about 1/2mm. Fixed that and fine now.My blue XRT keeps eating gears all of a sudden! It even ate saga gears and I don't know why. It seems to be happening in the air on jumps too. Anyone got a clue as to wtf is going on with my truck? the other two xrt's not having this problem.
Respect bro!! You jump them far better than I. Those cats like Rich and Eric make it look easy.. not so. I wish I had the coin those guys have spent on broken parts getting to that level. Which is why I don't even try.. just ain't got it like that. Keep up the great contenti'm still a pansy tbh. I did manage to man up and do a double flip the other day though. It was GLORIOUS! especially when you factor in my jumps are more distance than height.
I was talking about the pinion/spur and not the diffs. I was having some nasty diff problems as well though but like you, I fixed it by shimming the holy poop out of them haha. I don't know what was wrong with my blue XRT but the last bash was a success and I didn't shred the spur or pinion. I added a cover to the pinion/spur and replaced the gear cover that goes over the rear of the cush drive with an alu one. Problem seems to be fixed now!Had that in the XMaxx. The rear diff kept eating gears when jumping. Needed shimming internally. Not just one shim. As far as I remember about 1/2mm. Fixed that and fine now.
I'm always amazed at how well the TRX 8s rigs hold up considering all the plastic and the flex that comes with that..even stock power has the countershaft (spur shaft) flexing like a mother on the bench. Just imagine how much that shaft moves with the resistance of the truck against it! Wow. Then add motor movement from chassis flex and holy crap!! Likely the main cause of pinion/spur failures I've always thought..I was talking about the pinion/spur and not the diffs. I was having some nasty diff problems as well though but like you, I fixed it by shimming the holy poop out of them haha. I don't know what was wrong with my blue XRT but the last bash was a success and I didn't shred the spur or pinion. I added a cover to the pinion/spur and replaced the gear cover that goes over the rear of the cush drive with an alu one. Problem seems to be fixed now!
I've broken so many on the X-Maxx. Did really torture the car with high jumps but I think too many spur/pinions broken. All with stock ESC/Motor. Then at one time I had a pair that just lasted - Traxxas gear. Not sure why. So I think it could have been quality problem with the spur gear in general. But it also could have been too big a mesh with the pin system. At the same time I put the pins one setting tighter. It might also have been the problem.I was talking about the pinion/spur and not the diffs.
Stock guy here so, limited experience with big power but, I think the electronics will "tell" you if they aren't up to task by getting hot. If the connectors or wires are getting hot you likely need to step up?
Thats helpful, thanks! Do you use the 180, 120 or 90 degree servos?We have the same 60$ 80kg aliexpress servo in our xrts since day one and they're still going strong. I tried to put people on to these things. I even have them in my expensive ass mcd rigs.
Vitavon bellcrank is a must as well, that adjustable servo saver makes such a big difference.
https://www.aliexpress.us/item/3256804094242829.html
180!Thats helpful, thanks! Do you use the 180, 120 or 90 degree servos?
Stock cups that wore out? What a coincidence, I'm replacing mines right now!!XMaxx suddenly blocked gears after bashing last time. Total block and wheels would not turn when pushing the car. Felt like one differential was totally blocked. Took apart all three differentials - nothing. Then found the rear drive cups were worn too much and one dogbone got stuck sometimes in the worn drive cup blocking everything.
Problem now gone:
BTW, hopefully that fixed ur problem? Mine are worn similarly but I haven't had the wheels lock up. I can see the suspension jump up and down when I throttle the truck on the bench though..
