Beaker
So, in the quest for lower motor temps, without sacrificing gearing, I'm looking at motor heatsink/fans.
Came across this from Yeah Racing, running twin 30mm fans. Diameter is 40.8mm, length is 57.9mm.
There's also this from Hobbywing, running a single 48mm fan. Diameter is 44mm, length is 66mm.
The BLX 2050 is listed as 41.7mm diameter, 74mm length. The Yeah Racing one looks to be the better option to me, 0.9mm can probably be made to fit easy enough, of it needs modification at all. There's also air volume to consider which I haven't looked into yet.
I'm also no where near my Typhon, since I'm at work 600km away. Anyone with their buggy close that could have a look at the above dimensions, see if the heatsinks/fans should have ample room?
