- Thread starter
- #41
Finally getting somewhere! Coming along nicely. Got the rear T-Bone bumper, PPS motor mount and diff housing installed. Had to move the fans to the side because the cage support mounts on the PPS were hitting my custom Infidel67 fan mount. Might be an issue when I go to put the right side plastic back on. I have a long way to go before that's an issue!
All I have left to do is dismantle the front end and put in the HR diff housing, install the HR knuckles, install the T-Bone Racing front bumper, rebuild all of the diffs with Arrma aluminum cups, rebuild all of the shocks with the M2C caps and dampers, remount the esc... and that should be it!
Oops... I just realized I will have to remove the rear bumper again to install the HR front and rear blocks and M2C hinge pins! I also have to do the same on the front but I have to take that apart anyways.
