- BigRock
- Outcast 6s
- Outcast 8s
- Talion EXB
How big are they?@Johnny b thanks for the post. Ended up picking up two of those cans for 12.74 at Wally World tonight.
Absolutely Sir. Like stated aboveSo if I understand you correctly, your still latching it shut and its sufficiently vented with most of the seal removed?
To late. I already drilled 4 holes in the lid! I suppose I could bolt a steel plate over the inside cover to seal it up, plus it will give me something to do.Absolutely Sir. Like stated above
Yeah just leave a bit of seal near the latch so the latch has enough tension to remain secure under pressue. The can will still vent pressure fine with the rest of the seal removed. Don't make holes . Then fire will come out like a blow torch! Defeating the whole purpose of the can. Need to vent the pressure but contain the fire.
12 inches long.........6.125 inches wide....7.25 inch deep.How big are they?
Dang that is a little bigger than the Harbor Freight one.To late. I already drilled 4 holes in the lid! I suppose I could bolt a steel plate over the inside cover to seal it up, plus it will give me something to do.
Yep, me too. Didn't even know they had them till this thread.@Johnny b thanks for the post. Ended up picking up two of those cans for 12.74 at Wally World tonight.
Neither did I. I stopped at tsc and they were out so wally world was right around the corner. Sometimes even a blind mouse finds the cheese.Yep, me too. Didn't even know they had them till this thread.
I've seen a reddit user who stores his lipos in the oven since he lives in an apartment.I feel bad because my cans can't really close the way I have em I don't know how I'm carrying mine to balcony in case of emergency. Apartment life sucks for lipo tbh I'd be charging in the garage if I had one.
or microwave...just don't forget the're in there.lolI've seen a reddit user who stores his lipos in the oven since he lives in an apartment.
Maybe I should consider that! or a small bbq pit?I've seen a reddit user who stores his lipos in the oven since he lives in an apartment.
thanks!
I'm actually going to start charging mine in my table top weber grill out back.Maybe I should consider that! or a small bbq pit?
