Kraton Compatible Body Database
The bug body does...
The only issues I’ve found with the bug body is it doesn’t fit well in the front, which requires it flex inward. The first big bump resulted in a crack across the hood. I’m making a second version and extending the body posts to retain the molded bend of the hood. Also, based on the body trim, the rear holes tear easy. You can see the flex here. The stickers are just RC bondo :)
I filed down those outer tabs on the stock front shock Tower and it fits perfect. I know when I'm done with this bug body I'm going to get an aluminum front shock Tower anyways along with a different body so I didn't think it was a big deal.
Update on the bug body. This is after seven runs and only two crashes. didn't hold up very well looks like I'm going to go with the indestructible body next.
Hi guys, I wanted to start a list of bodies that fit the Kraton. I will keep this list updated over time.
Please share pictures and links to the bodies you have installed on a Kraton with any needed supporting mods and fitment notes!
1.) Chevy Longbed from Proline - No or minimal modding needed
https://www.prolineracing.com/bodie...x-e-revo-revo-3-3-mgt-long-bed-clear-body.asp
2.) LFR, Lead Finger Racing MBXT Body, no modding needed
http://shop.leadfingerrc.com/Strife-body-clear-for-MBX-7TR-LFRT4019.htm
3.) Traxxas Emax body
https://www.amainhobbies.com/traxxa...tk_HNlDJnAvQe5iu6x6p7Zwf0q5C4MChoCLsoQAvD_BwE
4.) 2014 proline silverado body fits well.
https://www.amainhobbies.com/prolin...o-monster-truck-body-clear-pro3430-00/p387184
5.) Summitlink VW baja
https://www.amazon.com/SummitLink-Volkswagen-Unpainted-Stickers-Thunder/dp/B01I9OTIEM
are all this for the 6s kraton or the 4s kraton??.
Since it was compiled before the 4s was released, these applications specifically for 6s. With that said, some of them may fit however they have not been tested. Some of these bodies were designed for 1/10 scale, so chances are good.
Jconcepts has a "finnisher" body specifically for the kraton. Search jconcepts kraton finnisher with two "n"s on eBay. Here's my kraton. I like it way better than the stock body. Cage fits under it perfectly. Far more durable so far. Pictures taken when it was first painted but only has one small crack after 10-12 packs and that was from a roof landing on gravel.
Found the part number and took a picture. Forgot I bought two and need to get the clear one masked so I can get it painted up
Proline RatRod body fits great.
ProlineRatRodBody
You will need proline body posts. Installed in the top hole on the shock tower.
ProlineExtendedBodyMounts
I was able to get the body to fit over the shock towers(front & back) and keep the wing. I did have to remove the lower aero part to fit around the bed and notch the part the tailgate by the wing mount. And the internal roll cage fits with no modification. The side debris guards are from the notorious because they are the same height front to back.
43159
43162
43163
I just picked up the a new #Finnisher for my #v3 #Kraton BLX 6s rig!
Then ones I get it, I will be sending it to a friend of mind that specializes in painting RC bodies!
For my colors that I have choose which is black and red on my body and some add some sort of stripe down the side.
This just an Example of the body painted that i have ordered for my BLX 6s KRATON!
Just got in my #Finnisher body for my #v3 #KRATON from #JConcepts. I am going to custom paint the body with some sort of Blue & Silver Metallic colors. I will be using my dermal & a Hobby Knife so I can get these clean cuts.. This will be my 1st body that I have done so any recommendations, would be greatly appercaited it???
prt#
