Granite Just made a long CVD for Granite with Typhon RPM arms
So I need the 4S CVD that connects to the diff. And the 3s CVD that connects to the wheel? I’m I understanding that right? Also do I need a washer/shim? I current have the 17mm hex adaptor on my granite would that still work with this set up? I’m tired of my U-Joins popping out when running 4s. TIA :)
The original post uses a hybrid of modified 3s and 4s parts. But the recently released Mojave 4s now provides all the parts for a driveshaft/wider stance/17mm hex upgrade with no modifications needed. Not sure if it’s cheaper. There are a number of parts.
So I would need the driveshaft and the arms to make it work? What about the bearings do I need new ones to accommodate the new Wheel block?
On page 6 and 7 you find all the info for the rear axle of the car, search for my post.
On this picture you see what you need. Part numbers are I think on page 6 or in my built thread.
Thank you so much for this! Just placed an order now the waiting game begins! Been running 4s and the U-join always pops out and it's really really annoying!
Hey @Neelis I just got my front and rear suspension in and I notice that the front arms are much smaller than the RPM ones on the wide stance. Do I just keep the RPM Arms from the typhon from the front and only have the Mojave rear Arms on the back? I
still don't have the wheel block delivered yet. Did I miss a step??
Thanks.
Wait for the blocks.
I only converted the rear, so I don't know how the front arms compare to each other.
I wish someone would have said that is not as wide of the RPM arms. I’m not really feeling it. What do you guys think? Should I go back and just do what the OP had done in the first place?
Are the RPM arms for a Typhon or a Kraton?
The width of the rear of my Typhon changed 1mm converting to Majove arms. This was with the original Arrma Typhon arms, I have in mind the RPM arms are the same size.
View attachment 367946View attachment 367947
First picture are Arrma and RPM arms for the Typhon. Second picture Typhons 3s vs Majove 4s.
The front axle is 30cm wide with Typhon arms and and 30.5cm in the rear with Mojave 4s arms. This is with the stock Typhon 3s wheel installed.
I am really curious whats going on with your RC.
The Typhon 3S and Big Rock 3S uses the longer arms.
Those new Mojave 4S arms is probably closer to Granite and Senton 3S arms..
The Mojave arms combined with the Mojave hubs are the same length as the Typhon arms + Typhon hubs:
Difference is about 1mm on the rear axle.
Well I completely missed ordering the 3x48.5mm hinge pins! 🤦‍♂️ For some reason I thought I could reuse the one from the Big Rock; they're too short at 3x31mm only.
https://www.arrma-rc.com/en/product/hinge-pin-3x48.5mm-4x4-2/ARAC5029.html
Otherwise ready to install:
Those front arms look really short though. 🤔
@GRC @Neelis or anyone else who did the Mojave conversion: Did you guys have trouble reusing the 4 mm hinge pins? I’m having a tough time getting mine to fit. All but 1 bind for some reason. Maybe they are slightly bent. I've ordered a fresh set to see.
Also, what size grub screw did you use to secure the cvd to the diff outdrive? 4mm? Not super clear from the diagram…
Hinge pin from my Typhon was fine, no binding.
4x4 grub screw is what you need brother!
Front arms do look really short, did Arrma introduce a Mojave Grom!?
This is the Mojave 4s top view, front arms look any from this view.
