I upgraded to Nero Bigrock.
KyoungRok Kim
An external CC BEC was installed for 7.4V,
The motor was changed to Tenshock X802L V2 6 Pole Motor 2200KV,
The pinion gear was replaced with 17T.
Servo replaced with Savox SV1270TG.
I replaced it with another Hot Racing metal part.
The GKA Rocker Arms is in order,
The upgrade process for my Nero Bigrock is over. :)
Looking good, what do you think of those axle carriers? I just picked up the Hot-Racing rocker arms and have been thinking about getting the axle carriers next.
I used Hotracing axle carriers, but I did not feel the need to replace them.
Rocker arms, Aluminum bearing steering, Aluminum Steering Bellcrank Mount only
If you replace it, you do not need to replace it anymore.
@KyoungRok Kim good looking truck, how do you like all the Hot Racing items?
I was replaced with curiosity.
Rocker arms, Aluminum bearing steering and Aluminum Steering Bellcrank Mount are satisfactory.
