Kaku
I have an arrma fury all stock and I just want to upgrade the motor to make it go faster. Is there a motor I can get in Australia to upgrade it. I need it in a budget of about $100-$200 aud.
Both the ESC and Servo plug into the receiver. Servo is channel 1, ESC is channel 2.Yes it's 2wd and I'm wondering how you would connect it to the receiver or if the wires for the receiver than the servo? Or does the servo connect to the receiver?
Do you reckon the ebay motor I linked will be good and it will work on a 2s lipoCool I'll keep that in mind for when I get my pay.
I was looking on ebay and would this be an upgrade and would it fit.
https://www.ebay.com.au/itm/125974440671?chn=ps&_ul=AU&_trkparms=ispr=1&amdata=enc:1TYZ_ygVGQUu9VZZIK7heKg36&norover=1&mkevt=1&mkrid=705-139619-5960-0&mkcid=2&mkscid=101&itemid=125974440671&targetid=1598469862318&device=m&mktype=pla&googleloc=9071766&poi=&campaignid=19657035767&mkgroupid=143201283022&rlsatarget=aud-1176464292956la-1598469862318&abcId=9305369&merchantid=710355775
What lipo would you recommend?
There should be a diagram in with the ESC/Motor user guide.Yes it's 2wd and I'm wondering how you would connect it to the receiver or if the wires for the receiver than the servo? Or does the servo connect to the receiver?
Absolutely, its a system. Cheap batteries don't provide current and droop (Voltage). Under powered ESC hold back the motor.Cool thanks that helps a lot but relating to my message before yours do you think that motor, esc and lipo will work together?
It’s important to check the dimensions of whichever LiPo you choose to make sure it will fit in your battery tray.Ok cool thanks
The lipo I was looking at
https://www.ebay.com.au/itm/2836018...uid=rpn6jb_mtmm&var=&widget_ver=artemis&media
