vorteks maniac
- Vorteks
the Bering still moves freely but the Bering won’t come off of the shaft.
On the motor? The shaft on the output gear is plastic, the pinion is metal and the spur is metal. I don’t have a dermalIs the pinion plastic?
Notes I saved over the years to get those off:
https://www.arrma-rc.com/en/interactive-exploded-view?pid=ARA4305V3T1I accidentally blew it up with a hammer but thank you for your help… also what size do you think it is?
To 'rescue' and old bearing that cost 1.5 euro?
FYI..suggesting the option of the availability of a proper tool for the job. Never pull bearing out applying force on the outer ring. Puller has to sit flush against inner ring. Same applies prying out with a screwdriver or any other tool.To 'rescue' and old bearing that cost 1.5 euro?
With a puller you most likely damage the balls, because you will pull on the outer ring. Is not something I would use.
